I’m using the “Sticky Action” to anchor an HTML box with menu items to the top of the page while my content scrolls underneath it. It works fine except: if I resize the viewport the sticky HTML box will not slide left & right (remain centered) with the content.
In fact, the Softpress homepage does what I’m trying to do:
Did you fix it? It doesn’t look broken here in Safari.
On Oct 15, 2014, at 10:59 AM, Rich Trowbridge email@hidden wrote:
Hello everyone.
if you look at the logo and the CSS Menu items while you resize the viewport, you’ll notice they do not slide horizontally with the rest of the page as they should. That’s what I’m trying to do.
What you see with the white HTML box is my workaround which disguises the problem a little. Watch the right side of the viewport when you move it: it’s cropping the white box not resizing it.
