I’ve created a carousel on this page to choose between downloadable PDFs (only 1 showing at the moment), and it works fine locally in Safari on my machine with the carousel scrolling left and right when the relevant text tab is clicked. Yet when uploaded, the carousel fails to scroll and the page moves vertically upwards instead!
I’ve checked it in both Safari and Firefox - both the same.
From the teach a man to fish department: all I did was choose Develop / Show Error Console in Safari. (If you don’t have the Develop menu enabled in the Advanced tab of Safari Preferences, you really should.) There, I saw that glider.js was 404 (missing) and that the Glider class was not defined as a result.
On Mar 9, 2012, at 10:20 AM, neil.west1 wrote:
Thanks Walter, you’ve done it again!
I uploaded the last modified files via FTP, so I’m not sure why the js.glider file ended up missing! Either way, problem solved. Thanks again.
