I am trying to do some tricks with the show/hide layers and I’m having a problem. Near the bottom of this page, http://www.flowersongherbals.com/herbals2.html
if you hover over the three links (brain power, clear lungs, cold & flu) you get the proper behavior. However, if you click on those links, it takes you to the top of the page. I don’t want this. It is especially a problem on mobile devices without the typical hover behavior.
I don’t see a way to adjust this. I’m using the text rollover action to select the target group and number I need. Ideally, I’d like the ability to format this text (at the very least make it larger), but I don’t see a way to do that either with the text rollover action. Is there a more flexible action I can use to get the results I need?
I want to be able to scroll over a list of 16-20 products, have the product image, info and buy button appear.
Insert a space character before and after the action then select the space-action-space sandwich and apply any styling you like.
You have the option of 10 Target Groups and 20 Target #s which gives you 200 variations. Show/hide items can share groups and #s so the same Rollover can trigger many different layers.
This can be overcome - there is an article on the Softpress site that covers it - let me see if I can find it for you.
