Hi Joe,
I am a little confused as me experience is slightly different.
When I am up against this very annoying situation, I do not make the page longer, I need to make the HTML box longer (6000pxls high) than the amount of text so I can edit the text without a problem,.
I have it on Auto overflow.
When I am done editing, I have to resize the HTML box back to the way it should appear on the site (358 pxl high).
No, that sounds different. Would you be able to copy the problem page into a new document and send it to us at support(a)softpress.com, please? Just select the page in the Site Panel (on the left) and hit Command-C to copy it. You can then create a new document and hit Command-V to copy it across.
Please remember to let us know exactly what it is we’re looking out for.
Thanks.
On 30 Jul 2012, at 14:07, Barry Hoffman email@hidden wrote:
Hi Joe,
Ok Walt and everyone, here is the official response from FW on this issue.
They saw my file and problem easily. Here is their response…
" I’ve had a look and I don’t have any problem editing text as long as I don’t try to highlight it. There seems to be a with the drawing of the selection. If you simply click somewhere in the text and start editing with the keyboard then it’s fine.
I’ll log a bug for the drawing issue. Thanks for pointing this out to us.
I assume most people hi-lite text when they edit or copy and paste so this is a large problem when editing HTML text that scrolls.
