Hello all,
I’m baffled. I’m working on a site, where I want a slideshow, and have been using the above actions.
http://mangosa.richardheap-server.info/
However as you’ll notice there are 2 problems:
- 1st image doesn’t stay on show for long enough
- Logo’s on the right jump in after the slideshow between the loop.
Where am I going wrong? Have followed guidelines, and researched here but to no avail!
Are you using the RPL action on this page? If so try it without.
Be careful about your image sizes http://mangosa.richardheap-server.info/Resources/aerial1.jpeg the background image is HUGE at nearly 1Mb - you could easily half that without discernible loss of quality - it is a bg image after all! Takes 4s to load at reasonable connection speeds.
As to the 1st image not hanging about long enough - have a look at this page http://www.deltadesign.co/examples/sequence.html - its settings might help.
Note that I have a base image that does not have the target show/hide action applied to it. It displays all the time but the others appear over the top of it.
Many thanks David, and apologies for the late reply - out of town at the moment - but I’ll check this out asap. And yep got the RPL on, so perhaps that’s it. Good point re image size too - this is all fairly new to me.
