As far as I know, there is no way within Freeway to extend individual
LIs in this manner. I could probably write an Action that you could
add (inline) within the line of text of an LI that could do this, but
other than that, no way to do the ID trick that I know of.
On May 6, 2009, at 6:14 AM, David Owen wrote:
How would it be best to individually style each li in a list with
unique icons (each different) in Freeway?
It would involve giving each il an id and using CSS to style add the
icon…
Thanks for chipping in Walter. That’s what I thought - but it was
worth asking just in case anyone had been here before.
individual LIs in this manner. I could probably write an Action that
you could add (inline) within the line of text of an LI that could
do this, but other than that, no way to do the ID trick that I know
of.
The easiest way to do this would be to use the List Item Styler action (http://actionsforge.com/actions/view/122-list-item-styler) and then you’d insert the action after each list item. Then in your Actions palette you’d then give it a unique class style and then in your CSS you could target the:
