hey Walt. a revisit to the sublime player.
the player is great so the problem is not that. what is happening on only this page is the css menu is out of whack
the spaces are not the same even as it is same as master content settings
all I could think the problem was is that the page is set at xhtml 1.0 strict
thx for any input
I have seen a variation in CSS Menus between HTML 4 and XHTML 1 (strict or transitional, makes no difference) but I have never traced down exactly why it happens. What you can do is switch all pages to XHTML, and then you can tweak the menu to look the way you want it to and know that it will be the same everywhere (no jarring shift between pages). If you want to take this to its logical conclusion, also apply my HTML 5 action to every other page (besides the one[s] with Sublime on them – they’re already converted). Then you have guaranteed consistency all the way through.
thx for any input
to get back to you Walt
I looked ate my master pages and all and it automatically switched to xhtml 1.0 strict
and I still cant get a sublime player in action palette
even when I make a clean new page
ugh
When you’re looking for it, do you have a Graphic Box selected on the page? You have to have one of those selected (corner handles showing) in order for the Action to be available. Also, double-check on your page in the third tab of the Page Inspector – make sure it is set to XHTML. It’s not enough to have changed it on the Document Setup (I don’t think that’s your problem exactly, but I wanted to be complete).
ugh
