The triangle below the sub menu is again doable but you’ll need to add your own CSS styles to target the last child of the menu and add your own background image (for example).
Here’s an example of a Freeway 6 Pro file that uses a similar style but was created with just CSS; http://www.freewaystyle.com/testimonial-panels
It is a lot more complicated than just using an image but it may be worth pulling this example apart if you have time.
On 11 Feb 2014, at 14:38, Erik wrote:
Is it possible in freeway to add a background box like this which is popping out with the small triangle below?
