[Pro] Supersizer Question
I am trying to understand why the Background Supersizer doesn’t work as smooth as it should on my index page.
There are 16 jpgs in the folder, all bet. 178 and 343 KB.
http://invisiblestudio.com/BckSupersizer/
On Safari, Freeway, Chrome, iPad and iPhone
the page opens with a blank ( black ) background.
You need several seconds of patience to see the first image loading. Around the 6th image or even earlier, the black background reappears, and the following images load segmented and fragmented, or altogether skipped. Once in the cashe everything works fine but I don’t expect anybody to have the patience with the way it starts.
I really like the idea whole background “slideshow” and I saw it implemented beautifully.
Could somebody could shed some light on my mishandling of this Action? I would be thankful.( as always ).
In advance,
VGP
Even though still uncertain about it, I will try to answer my own question, in case somebody else might go through the same.
It looks like the choppy, fragmented Supersizer problem I have is caused by the action starting before the complete loading of all images in the browser the first time around. So, it might be a slow connection on my side, made even worse by a large number of files. I reduced the Supersizer folder to 10 from 16, keep my fingers crossed and it works better, with the occasional hiccup though. Again, once in the cache, all is well.
VGP
You could reduce the file size of the images quite a bit more by reducing their physical size. Currently they are at 1200 x 900.
Try them at 900 x 675 and reduce the quality some more.
You can do this simply in Preview by doing a Save As and then using the Quality Slider to reduce them.
If you want to display them elsewhere on your site at a better quality then at least your visitors can have the choice.
Thank you D., I will try that.
VGP
I even use 1MB images sometimes, 1920x1200px wide … and I don’t have this issue, not local and not live.
For you, is this purely a local or live issue? Both?
Richard
Hi Richard,
Both, and I was surprised to see how the flow of images was
chocking on all devices. I think it has to do with both the amount of images and size. After reducing the Supersizer folder 10 from 16 it was better. I guess with 5 I would’t have any surprises, but in the end I decided for Random Background.
VGP
Need to correct that: the problem was live, never local.
Sorry for the confusion.
VGP
Problem revisited.
I think I know what could go wrong: faster speed than the default ( 700, length btw.transitions 3000 ). I used to have faster settings, ( I wish I have a record of that ) and the slideshow bottlenecked usually at around 6-7th image. It works well now with the default.
Great action, thank you,
VGP
