[Pro] Supersizer with fixed height
Hello,
Maybe someone can help me with this;
I want to make a slide show full page (width) but fixed height like the one on this site:
With Background supersizer I can’t set the height myself
is there a other wat to create this?
Thank you!
Erik
This more a carousel than a background slideshow.
Try using a full width carousel with bg images instead. Haven’t tried it myself!
Hi David,
Thanks for your reaction,
Don’t realy understand what you mean, tried some things but it doesn’t work.
Is it possible you are a little more specific, or maybe a simple example would help?
Thank you for your time
ErikB
See if this helps http://www.deltadesign.co/big-carousel/
Hi Dave,
That looks like someting!!
Can you send me the Freeway file so I can analyse how you did this?
Very much thanks for your help!
ErikB
Sorry, found the link already, super!!
