Hello, I’m very new in “website making”, I work with FW because I have a “quark/indesign” background. No knowledge of HTML, CSS.
I try to embed a “svBuilder” code and nothing happens.
Have you uploaded the SimpleViewer package to your hosting set up? It’s trying to call the “simpleviewer.js” file and you’ll have to make sure it can connect to it along that path.
to attach the “simpleviewer.js” file into your Resources folder and then when you upload your site, it should connect since you changed the location of the file.
Hi, thanks for the info.
I can’t make it “work”. I will dig deeper to it later. I was just trying out different “slideshow apps” as “Showcase” is a little limited. Would you recommend an alternative for “Showcase” (no HTML, etc. involved)?
(Have you uploaded the SimpleViewer package to your hosting set up? ???)
Well how do you plan to load the SimpleViewer package when you haven’t uploaded the folder containing your gallery items and what not? If you don’t upload the package then you’re trying to load nothing in that call to the “simpleviewer.js” file.
I’ve never used SimpleViewer but it looks like there is some uploading involved first that has to occur (gallery items, etc) before it works.
