On the updated site which is still work in progress, the copyright symbol is being displayed as a triangle with a ? inside, and the code FW generates is :-
� Glandore Yacht Club 2013
The Text settings in the Document Setup are identical between the two sites.
The suggestions made no difference to the problem, just to check my problem again i have been Previewing the page from within FW and it seems to be OK. I noted on some blogs that this problem can be produced by the server, not sure how, but, it looks as if my issue maybe server related as it displays OK locally… which could make sense as the working site and the experimental sites are on totally different servers.
Keep trying different encodings, perhaps in the Windows Latin end of the pool. Once you find one that matches up with the content-type signature that your server is sending, you should be able to stick to it. If you have Firebug there, you may want to look at the headers that your server is sending, that might make the traipse through the encodings list a little shorter.
On Dec 17, 2012, at 10:09 AM, ejw wrote:
Walter/Thomas,
Thank you for the guidance, now that i know what the problem is and the fact that the development site will move to the online server, i will leave the fault fixing on the Dev server.
