I’ve been trying for hours to get tabbed areas to work in FW6, but no luck at all. Are there any examples which are working with Freeway 6?
The actions are not working for me either (javascript error) - support(at)softpress.com I think is the call.
Meantime can you give us an example of what you are trying to achieve and we can maybe offer a workaround.
Hi David,
I need to make three or four tabs in a page using inline divs, so height can grow. Just text tabs with a background color.
Have a look at http://freewaytalk.net/thread/view/108965#m_109166
Hi David, thanks for the reply.
Yes, I did tried that one, but it didn’t work. Works for me in FW5, but not in FW6.
Anyway, problem solved, using crowbar and some javascript I just found on the net.
