How would I do this since I cannot “move” the image around in the cell where I want using the HTML method; I could as a graphic though.
Do I have to edit first in Photoshop?
I hope this makes sense…
So, in the cell I only want a glimmer of the picture, not the entire thing; the way it is now, I just inserted the picture and moved it with the hand until it looked good.
A background image is unchanged by FW so if you only want a section of the image then crop it in Photoshop first - Preview will do it too.
But once you have that bg image you can alter its position in FW using the Horizontal and Vertical positioning settings ie Horizontal: Center, Vertical: Bottom
I read above and added 10pxls to the titles which looks better, then I went back and read your note and realized you did NOT mean the TITLES but the actual text in the cells.
gonna do that now. Hope there is an easy way to do all instead of each line.
Oh by the way Dave, that is exactly the kind of suggestions that really truly helps- I would never have noticed something like the indent. I really appreciate that, and any suggestions you ever wanna give.
Barry
On 2 Jul 2012, 12:29 am, DeltaDave wrote:
Can I also suggest that you add some indent to the text in your main cells.
At the moment the text butts right up against the left of the cell making a bit more difficult to read.
Rather than indenting the text lines, try adding padding to the table cell.
On Jul 1, 2012, at 9:06 PM, Barry Hoffman wrote:
Hey Dave,
