[Pro] Target Groups not playing well together
I have 25 thumbnails and their respective images set up to appear during rollover. The first 20 I have in the Indigo Group and the last (or bottom 5) are in the Rose Group. The first (Indigo) 20 work great, they appear and disappear when they’re supposed to.
The Bottom 5 images (of the Rose Group) stay visible, blocking the upper images.
Please help. I feel like I’ve tried every combo of settings but I know I’m doing something (probably simple) wrong.
Here is the link to the page:
http://www.emilyfarranto.com/
Thanks!
Groups operate independently from one another. That is, if you turn to a new group, the option left open in the old group will not “hide” the way that it would if you picked another option inside the same group.
The solution is to use the “60” versions of these Actions, available at ActionsForge.
http://www.actionsforge.com/projects/view/59
Thank you very much Walter. It was really cool of you to get back to me so quickly. It worked like a charm. Thanks again!
