[Pro] Target Image and Rollover Problem
Hi everyone,
I’ve run into a problem which I hope someone has dealt with and can help :slight_smile:
I’m working on a new portfolio section for our site, which I have setup using the Target Image and Rollover actions. You can see it here: http://minimoko.com/demo/minimoko/what-we-have-been-working-on.html
Rollovers are working exactly as I want them to but when I click on the thumbnails it sends me to the top of the page. I have tried changing the rollover setting to also change the target image on click but I still get the same.
Does anyone know how to get around this?
Harry
Are you using 5.5? I am having issues with target image and rollover also: I am unable to combine graphics.
Hi Nick,
I’m using 5.4.3, what problem are you having?
I found a solution to my problem (although it will add a bit more time to my work). I have added an anchor to the main image section and then a link to that anchor on each thumbnail. Seems to work ok.
If anyone has any other idea, please let me know :slight_smile:
Hi Harry
This should sort your problem Prevent Rollovers with no Links from Jumping to the Top of the Page - Freeway - Softpress Talk
Hi David,
Thanks for the link! this really helps.
Harry
