[Pro] Target Images
Hi there,
If anyone can help me I’d be so grateful. I’ve followed the Freeway Pro tutorial and set my website up using the knowledge gained from this. Anyway, I’ve got to the stage where I’ve made rollover thumbnails and target images, set it all up like the tutorial only to find I am limited to 20 images per target group and I need 25. How on earth do I configure these remaining five target images to the remaining five rollovers? Every time I try to change the target group name to link up the remaining five it throws the other 20 images that work perfectly out of whack. Not sure if I’m making any sense. Really I’m just trying to find out what you do when you have more than 20 target images. I am a complete novice, so if any of you kind people can advise me I’ll need very simplistic info.
Thanks in advance.
Amy
There’s a set of Target Actions on the ActionsForge that go up to 60.
I think that will hold you over…
On Jun 16, 2009, at 1:01 PM, Amy Blay wrote:
Hi there,
Get these extended Actions:
http://www.actionsforge.com/projects/view/59-trigger-and-targets-60
Colin
On 16 Jun 2009, at 18:01, Amy Blay wrote:
Hi there,
Thanks in advance.
Amy
Thank you. Now how do I go about setting these new actions to work? I’ve downloaded them and supposedly installed them. I am a complete novice, sorry.
Amy
Thanks Colin and Walter. It’s blimmin well worked!!! You’ve saved my husband from a verbal and physical battering. You are both stars!!!
Amy
