rbpspc
(rbpspc)
21
ah no! but it still doesn’t work
got the rollover working - image disappears on mouse-enter
BUT
cannot see the slideshow underneath
see a solid colored rectangle instead of images underneath (different color for all 5 panels)
going to try removing all pass-through images and see what happens…
rbpspc
(rbpspc)
22
thanks Walt
I’ve been doing exactly in the order you suggest
rollover working fine
problem is, on mouseover, it does NOT reveal what’s underneath - i.e. even though content removed, rollover image is not ‘clear’
even built a separate page with just 3 elements to test - clear rollover does NOT reveal an image underneath
thoughts?
rbpspc
(rbpspc)
23
aha! made the rollover image PNG and transparency works!
rbpspc
(rbpspc)
24
and PNG works to reveal the slideshows! progress…
rbpspc
(rbpspc)
25
page in beta:
http://h5.4u2bu.org
proof of concept
content still under construction
thanks for help!
