[Pro] testing a site
Hi, I need to show a client his site without making it ‘live’, can anyone help me with a way to do this?
Regards
Steve
If you have access to your / your clients server using and FTP tool (Transmit for example) you can create a folder on there called /lab (or any name really?. Then you can upload the site into it rather than into the root directory as you normally would. If you have access to the cPanel then you can password this folder too.
Does that make sense?
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
Regards
Steve
I have access to server as i run my own reseller webfusion account so all you say is Ok for me.
Just need to ask that when I upload in freeway do i put the folders name in the ‘directory’ field?
Also, once it’s up, how do I access the site from a browser? What url do I input?
Regards
Steve
Nathan Garner
Regards
Steve
Hi Steve
This is a screen grab of the upload window I have for my client. I have put a folder on their server called ‘lab’.
http://www.austinwellsdesign.co.uk/clients/upload.png
You will see I am uploading into the directory /lab/ and you will also see the URL you can type into the browser at the bottom.
Nathan Garner
Regards
Steve
Nathan Garner
Regards
Steve
Hi Nathan,
Thanks for this!
Regards
Steve
On 16 Nov 2010, at 21:41, Nathan Garner wrote:
Hi Steve
Nathan Garner
Regards
Steve
Nathan Garner
Regards
Steve
