Hi,
I’m using contact form for a website i’m building, and i"m using Hebrew Language which is RIGHT TO LEFT. I want that when i type in the text field it aligns to the left and i need it to be stating from the right. i’ve tried styling the text field but if you type in the field it aligns to the left.
Can it be solved?
Click on each of the form fields and text area in turn and select Item > Extended
In the dialog box click New
Enter;
value: RTL
Click OK until you get back to your document.
Preview and test the form
Can it be solved?
