[Pro] Text Formatting
Hi Guys, I’m new to the forum and have limited experience on Freeway.
I’m using version 7 and the second sight responsive template.
I am using Myriad Pro Light text, but when I preview, it is in bold? I have adjusted the CSS and the normal text formatting, but no change.
If I change the text from HTML to GIF, it comes out perfect. I am sure it is something simple…at least for you guys!
Any help would be greatly appreciated.
Thanks…T.
I am sure it is something simple….at least for you guys!
Post a link to your example online and we can check the underlying code to see where the Bold attribute is coming from.
Otherwise we can only guess. Have you selected it as an H1,h2 or h3 - which are automatically bold?
