Wow, that’s kinda dangerous layout-wise. Try zooming the page with Zoom Text Only selected in the View menu. Your text is going to run away from the paw prints. I would do this another way entirely. Make one paragraph style for the questions, and another paragraph style for the answers. Select all of the text and choose Remove Styles from the Styles palette. Then go through the text and apply your styles. Go back into the Edit Styles dialog and select your question style. Set the paw print as the background image in that style. Be sure you set it to not repeat, and align left and center vertically. Use the Extended dialog to add some padding, so the paw doesn’t slip behind the type. Try this:
padding: 8px 0 8px 36px
Then in your answer style, use a bunch of left padding to simulate the indent. About 80px ought to do it.
Here’s how it looks hand-coded with CSS.
http://scripty.walterdavisstudio.com/puppies.html
You’ll need to view source and reverse-engineer the styles a bit to get them into Freeway, but once you do you’ll have a clean layout without a bunch of extra markup to hold the images. (Fragile markup that won’t look the same in two different browsers, I might add.)
On Nov 21, 2012, at 5:47 PM, Doty wrote:
I’ve run into this problem before, but I’ve yet to fix it. In this page, I have the Q&A contained in a single text box. I’ve included the paw prints as separate graphics, but to make them align properly I have to move them way out of position in FW to make them show up where I wan after uploading. Also, to make the text flow better and increased size, I’ve applied RPL to this page.
Is this just the way it is in FW, or am I doing something in my creation of the page incorrectly?
Thanks, everyone!
Doty
http://invertministries.com/faq.html
