David2
(David)
June 12, 2011, 9:15pm
1
Hi
This is probably simple to fix… My text is suddenly outputting with the html tags, ie. instead of displaying “This is a sample”, I get “<.body>This is a sample”.
How do I get back to unlabled text?
Thanks, David
Can you post a link?
But what usually sorts this is selecting the text, removing the styling and then reapplying a style. Unless you have a malformed style in there.
David2
(David)
June 12, 2011, 10:29pm
3
Nothing is uploaded yet.
I tried remove styling and reapplying to no avail.
What’s a malformed style? I did edit styles to (Ha-ha) simplify my work, so I could have easily done something wrong…
How does it appear with no styling at all - any mention of any tags then?
But difficult to diagnose without seeing underlying code.
David2
(David)
June 13, 2011, 6:08am
5
OK I uploaded a somewhat woeful version of the site. It’s at http://www.sacred-silk-art.com/
On the home page, styling is removed, and no tags.
On the gallery pages the styling is still there, and so are the tags. The links are not altogether sound, but hopefully you can at least see what I’m doing…
Thanks for your help!
DT
David2
(David)
June 13, 2011, 5:56pm
6
David - I think I figured it out.
I had a tag shown as “.body” when it should have been just “body”, without the dot.
Not that I understand why, but it’s OK with me that it works now.
Thanks again,
DT
Glad you found that - another thing to look out for is image sizes
p1000372_2.jpg - size348.44KB
This is pretty huge for a bg image
http://www.deltadesign.co/examples/heart.html - this page uses your image compressed to <50K
Do you see any quality issues with it? - and you could compress it more!
David2
(David)
June 14, 2011, 4:53am
8
Great tip, David. Thank you. Maybe that’s why freeway was crashing now and then…
I will change the size in File-Export for all my gallery images as well… unless there is a better way to do this.
I feel like I’m learning fast, but there is certainly a daunting amount of ice under this iceberg!
Cheers, DT
If you are talking about a Showcase gallery then you have the option to use the images as pass-through.
You would then optimise these images in an external image editor pshop etc. before selecting them for/in Showcase
Also have a look at http://freewaytalk.net/thread/view/91947
And crashes in FW are quite often related to Font issues
Well worth running some sort of Font checking app like Font Book, Font Doctor etc.
