Is there a control for opacity of text? I can’t find it if there is…
Intaglio mailing list
Sure. Go to “Fill:” and have a play with the “Opacity”-slider.
Frank
Hmm, I thought I had tried that…
When I do that, my text loses its color (seems to get converted to a gray-scale mask, maybe?).
Decreasing opacity means less color - no??
Without an example it´s quite hard to tell.
I’ll try to post something later. But in this case, the characters are relatively light faded green, and they change to relatively dark neutral gray.
Open the Fill, Gradient and Solid Color palettes (Window menu)—see the screengrab.
