Brilliant Dave, I searched the 500 odd pages of FW Reference and must be so blind as to have missed it, ( must be the new Preview layout in Lion, not used to it yet) else I wouldn’t have troubled you.
Thank you for solving my similar problem, Dave. Although there was no other text than what was being used as rollover and the text was in a table cell, I merely put a dot before and after the text the same color as the page and voila.
There is an obvious answer to this, I’m sure, but how can you select a space before the text.
I am using individual cells within a table. When I go to select before applying the rollover action, I seem to be unable to select with a space before the text, after no problem. Possibly there is a command to select the entire cell including the spaces within?
I was able to select with the spaces by typing a couple of spaces before the text and after. Still coming up with wrong size font from the action.
An online example would help us diagnose your issue. Besides - unless you use a non-breaking space you dont get multiple spaces in your html - the web view ignores multiples.
