I’m trying to create a text rollover. After adding the action, how do I incorporate the target group and mouseover? Is there another action involved?
Is your text rollover to trigger something else? If so what?
Yes, to trigger an image.
Jacob
If you are wishing to do something like this http://www.deltadesign.co/examples/text-rollover.html
Then insert your Text Rollover action within a run of text between ‘My text’ and ‘then more text’ in my example.
Draw/create a Div (layered item) mine has a picture in it but it could be text or both. Apply the Target Show/Hide Layer action to it (or Target Show/Hide Image if just an image)
The settings I have used in my image/layer are:
Initially:Hidden, Restore:Yes, Effect:Fade, Duration: 0.5, Target Group:Indigo and Target #: 1
Go back and select the Text Rollover action and in the action palette set
Text: ‘link here’, Target Group: Indigo and Mouseover #: 1
Target Group and Mouseover# must match those you set for the Target Show/Hide Layer action
Thanks a ton. Worked great. Is there anywhere else besides this listserve where this type of information is available and this easily understood?
Thanks again,
Jacob
