[Pro] Thumbnails/Rollovers with Sequence Timer
My sequence timer is working fine. I wanted to add either thumbnails or buttons below the images that are fading in and out so thats it is possible to go back to an image that has already passed.
I did this by making the buttons rollovers that will bring up the proper image in the sequence. It technically works, but once the rollover is activated and the image comes up, how long it stays on the page depends on where the timer is at in its rotation. Sometimes it is up for a few seconds, but sometimes it will disappear immediately if the timer is ready to switch to the next image.
You can see what I have so far at syracuseguitars.com
Is there any way this can work that will essentially reset the timer once the rollover is triggered. Ideally, I would like it to work so that (for example) when the 3rd image shows up in the timer and you then go back to a previous image, say the 1st image, the next image pulled up by the timer will be the 2nd image instead of jumping to the 4th one. I don’t know if that makes any sense.
Any advice would be appreciated, thanks!
http://syracuseguitars.com
Forgot I need the http:// to insert a link.
