Thanks Max
Thanks Max
Hi Max
Not sure if the email will get to you as it’s hidden from view so just in case you can get in touch via my website
Much thanks in advance
Frank
If you really want to have your contact info available for the world (and its spam-bots) to see, you can replace the @ with ( a ) and it will magically turn into a clickable e-mail link. Or better, just put your contact info in your profile, and only registered members can see it.
On Jun 3, 2017, at 2:58 PM, Frank email@hidden wrote:
Hi Max
Not sure if the email will get to you as it’s hidden from view so just in case you can get in touch via my websiteMuch thanks in advance
Frank
Thanks Walter, Ive just checked and my email seems to be in my profile though I can see there are many other ‘Frank’ so I’ve added my surname.
Otherwise Max can find the email on my website.
Regards
Fran
