I’m getting the same problem (also using Focus theme and latest version of Freeway Pro).
I’d like the title and caption text to drop down below the photo if possible.
Exhibeo mailing list
You will need to view on a mobile to see what I mean about the text running over the images (when you click on one of the images to bring up the slideshow).
On a desktop it’s okays the text only comes up when you hover over the image; on mobile and tablet you don’t have that option.
tim
The problem is that the amount of offset required (bottom: -75px) will be different depending on how much text you have in your captions. One setting will not suit all.
So unless you limit the amount of text in the caption the best way would probably be to hide the caption on smaller width devices.
Something like
<style type="text/css">
@media only screen and (max-device-width:768px) {
figcaption { display: none; }
</style>
But I think it looks fine on iPad portrait so maybe reduce that 768 to 667 (iPhone6 landscape size)
This will place the caption below the image regardless of the height of the image so the caption will always be below it. Obviously you still run into issues with the caption clashing with the navigation or simply overflowing over the viewable screen area so hiding the caption on smaller screens is possibly the easiest thing to do here.
Hi Tim,
As Dave mentioned touch screen devices won’t show the captions anyway as they don’t have any concept of hovering over an element. If you test your gallery on a phone or tablet you’ll see that the captions don’t show. I suspect you are testing your site on a desktop browser which does support hover events and therefore shows the captions.
Hi Tim,
They shouldn’t be. I tested it on my Android (Lollipop) phone before I send my last email and the captions weren’t shown.
Regardless of this you can use the code Dave suggested earlier to hide the captions from all devices based on the screen width of the browser;
</style>
Change the 768 number to the largest device width you want the captions hidden on and paste the code into your page using the Page > HTML Markup > Before option.
Thanks. I’ve just checked again on my mobile and what seems to be happening is that the captions will disappear if I tap a different part of the screen. BUT not on all of them. Is there some sort of time delay do you reckon?
I feel like I’m almost there…
I’ve just tried your page again on my phone and none of the captions appear wherever I click. It could be the browser you are using (I’m using the stock Android Chrome) interpreting the hover styles (the CSS that shows the captions) and displaying them on a long press or other gesture. If you’ve added the CSS I previously mentioned then the captions should be hidden on all devices below the specified screen size regardless of where you press and for how long. Essentially the code simply says “if the screen is smaller than this then hide these elements”.
