Does anyone know why on some of my pages and under most of my words (home, about us, contact us…etc…) there are double underlines…these words are hyperlinked.
The double underline does not show up in preview when i’m in freeway pro working on my pages…it only shows up when i look at my website in firefox and safari on the browsers.
The only tab that doesn’t have double underline is the ‘shoe info’ tab.
I don’t understand why and how to resolve this. Does anyone have any information/solution on this.
what is your website?
On Dec 15, 2010, at 9:09 AM, Bugboots wrote:
Hi,
Thank you for your suggestion. My little one got up in the middle of the night when I posted my question. I went into her bed just for 5 mins and woke up 5 hours later.
I found the links in the inspector pallette settings and have turned the 4 U’s to grey and that has done the trick. I’m assuming its ok to have all 4 U’s grey.
Now that you have got rid of the underline you should probably add/change the hover link colours so that it is more obvious they are links when rolled over.
I have gone back to the underline thing again for now as you brought up a good point about how are people going to see that its a link.
I have tried what you suggested but it’s not working out for me. I used the Page Inspector - Links. There is nothing under Item Inspector. I will try to do it again another time because at the moment it’s getting frustrating that I can’t work it out even with your instructions. Feeling a bit dumb, I will tackle it again soon. At least I know how to fix the underline thing, just have to figure out the hover thing you said…
The settings are there. I am selecting the container. Its just when I change the colour of the hover, when i look in the browser it hasn’t done anything.
Is it maybe because the text is in a HTML item. Would it work better if I made it a Graphic Item?
<meta name="google-site-verification" content="4Ql_vfBPG9zP2sTPOa7Vkb5vVTqaqMj_QubrQ75rr74" />
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
I am pretty sure that is not the correct place for the google site verification code.
That is what I have. I have changed all the colours like in your example. I have the U’s highlighted and not highlighted - doesn’t make a difference.
The text is in a HTML box. There is nothing else done to it eg. I haven’t applied any test rollover actions to it because when I do it creates a new box that doesn’t do anything for my text and you can’t type text into that rollover box anyway.
I’m obviuosly a lost cause. I applaud your persistence to help me.
I’m seeing and doing everything you have showed me but its just not showing up in the browser the when i check to see if it works.
Will it only maybe show up once I have uploaded it or shouldn’t make a difference, I should be able to check if it works in the browser preview before uploading?
Ok, I finally got somewhere with the text rollover stuff.
I basically started from scratch, created new boxes and hyperlinks and it works a treat. So now I’ll re-do all my HTML boxes and hopefully it will work.
Now, just to tackle the Page Code stuff…It’s never ending, just when you think its all set up and working.
