Nate
(Nate)
December 14, 2011, 2:44pm
1
Can I create something like this in freeway?
http://www.6wunderkinder.com/wunderlist/
The top blue bar that appears and dissapears when you X out is the effect that I want.
waltd
(Walter Davis)
December 14, 2011, 2:48pm
2
TransitionFX Action, applied to the bar, set to Blind Down on page load, another copy of the same action applied to the button, set to Blind Up the bar. (You can apply an Action to an element which will then control a different element.)
That’s a cool feature. Where can you get TransitionFX?
Silly me. It’s in Freeway Pro.
Nate
(Nate)
December 15, 2011, 6:28pm
5
I have the bar coming down with the TransitionFX, it works great.
http://elysium.aswebsitedesign.com/untitled1a.html
I do not know how to make the bar “grow” or “shrink” to the page size.
Do you know how to make the bar do that?
