Sorry if this has been suggested, I’ve just come to this.
LLE Freeway mailto:email@hidden
9 February 2011 22:34
Tim,
your script works … Almost
here is the source text for the first two rows of one of my tables.
Your script extracted “strong,strong,strong” for the first Row, not
ANIMAL,NUMBER CLIPS,COMMENTS . It got the rest of the rows correct,
e.g. Cats,3,A black cat
I had applied “Bold” to the text in the first row.
LLE
On Feb 8, 2011, at 7:30 PM, Tim Plumb wrote:
Don’t give up yet - it’s just getting interesting!
Try the following action;
http://www.freewayactions.com/code/?f=Extract+CSV+data.fwaction
(Click the ‘Download file’ button and install the resulting action in
Freeway as normal).
Apply the action to your data table and publish as normal. The action
will run through the table structure extracting the data from the
table row > table data > p content. When done it will present this to
you in a dialog box. Simply copy this CSV text and paste it into Excel
or a plain text editor and then import the data into your spreadsheet.
I’ve tested the action on exactly one large-ish data table so if it
falls over and dies let me know and I’ll try and fix it for you.
On 8 Feb 2011, at 22:34, Cos wrote:
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
Tim Plumb mailto:email@hidden
9 February 2011 00:30
Freeway as normal).
Express & Pro.
Cos mailto:email@hidden
8 February 2011 22:34
Thank you gents,
This all sound rather complicated, so I will shelve the idea for the
present. I would like to thank you for your time and help with what I
thought may be an easy task! How wrong can one be?
Many thanks
Regards
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
ANIMAL |
NUMBER CLIPS |
COMMENTS |
Cats |
3
A
black cat |
