Hi All,
I’m trying to use the ‘Transition FX’ action to create a blind up effect from the bottom.
I have tried 3 varaitions of this effect:
http://www.edwardlawlor.co.uk/2011/inano/fx.html
It the one from the bottom of the page that I wish to work in a way so that it always stick to the bottom of the page regardless of the browser window size, or when you scroll down the page!
Currently it doesn’t do that? Is this possible?
Many thanks
Worm
