Since I already have the website live (believe it or not, but people were asking for it) and the effect really bothered me and could not get it solved, I decided to make them all visible.
Hi Dave. In the past I believe it was called show/hide layer and it worked perfectly for me.
Now yesterday with the Transition FX, the settings looked the same, but the effect itself was really bad. When I had about six boxes with the effect applied, really everything was going wrong. I double checked all the names and targets, but they all looked good.
So I decided to remove the action and actually it looks great so I will leave it that way.
This afternoon I added a fake ordering button with this effect and now the effect works like I expect it to.
If I ever need this effect again, I will learn how to use the ScriptyAccordion action. I’ve never used this one so thanks for pointing me in that direction.
If you want to see the effect working properly, please check out http://tarrels.eu/faq.html and click the big red fake ordering button.
