Mr_worm1
(Mr worm)
1
Getting javascript errors!!!
What the latest version of this? Im using 1.0.11
Looked on actionsforge but cant find it??? Has thsi now been replaced?
Worm
That is the same version as mine but I am running FW 5.6.4 and it is a core action.
Remove any instances of the action in your pages and publish.
Reapply the action and try again.
Mr_worm1
(Mr worm)
3
Thank Dave,
Issue still persist?!!!
TRANSITION FX - the item has no properties.
Line of code below is underlined in red in the java error.
var the Tag = theItem.fwEnclosing;
Also having java errors with my validate action too! Running validate 1.0
Worm
Clear errors, remove actions, republish.
Shut down FW and restart your Mac.
Reapply actions and try again.
Mr_worm1
(Mr worm)
5
Did this D, again with no luck!
Seems to come into play when I apply a second Transition FX action to the page…
I also have no idea why the validate action is causing java errors now too!
Attached a link of page (with ERRORS) if you could take a look pls. (Click the contact tab at the top)
http://www.cmlmarketing.com/2012/14793/V2/index.html
Heres how it should work:
http://www.cmlmarketing.com/2012/14793/index.html
Many thanks
Worm
Mr_worm1
(Mr worm)
6
You can see the form fields dont even show either?!!
I cant apply the validate action at all as it just won’t publish, maybe their is an issue with the CONTACT-FX-DIV?
Worm
Joe2
(Joe)
7
Do you have any other Actions applied to the page?
Worm
Mr_worm1
(Mr worm)
8
Yes, both Page actions & Item actions!
Alot indeed… to remove all, publish & re-apply would be like like asking me to read the bible twice!!! lol First time round was bad enough
Fingers crossed I can find a work around, not helped by the weight of this page & demands of client.
Worm
