[Pro] Transparent PNGs
Made some transparent PNGs in Illustrator, and finished them off in Photoshop, but in Exhibeo - and therefore Freeway - they display as black. Does Exhibeo like transparent PNGs?
Gavin
Exhibeo mailing list
I don’t think Exhibeo does any transparency at the moment. The images are
all “handled” - there are no “pass through” options.
Gavin
Thanks, Ernie. Will try and work around it.
Gavin
Just chiming in to lament this as well - got a large number of client PNGs with transparent BG - and now have to edit them all - or use another slideshow option. :frowning:
Hi Karen,
We’ve got a solution for this road-mapped for the next major version. For now, you could drop the PNGs into Exhibeo, output the file, open it up and replace the images and their paths in the body text file.
Cheers,
