[Pro] Troubles uploading Freeway 7 Pro
I have a new iMac running OS 10.9 Maverick and Freeway 7 pro. All my files were migrated over from my older iMac. I had Freeeway Pro 4.4.2. My Freeway site (wadehayes-woww.com) will not upload.
Here is the error message:
Cannot complete upload because a file could not be uploaded to the server [425 Could not open data connection to port 55327: Connection refused]
Sometimes I get that message halfway through uploading, sometimes 75% through uploading. Same message EXCEPT the port number changes
I’m attempting to upload to HaveHost. I have checked with them - OK on their end. My iWeb site is uploading easily to the same host. I’d appreciate any help. Thanks. Helen N
I have several sites there with no upload issues.
First thing to try is the old Passive/Non-Passive switcheroo chestnut.
File>Document Setup and then under the Upload Tab try changing the FTP Mode - I have no issues with Auto to HH but try the other 2 as well.
Thanks so much, David! You solved the problem! I had already tried Automatic and Passive. They didn’t work, but Non-Passive did.
