[Pro] Two bugs?
Hi Panel! I enjoy using Freeway, but here are a couple of minor irritations which might be fixable in future. I use an iMac with OSX.
• I have set up a couple of keyboard shortcuts for setting Rollovers and Set Target Layer. These work fine, except for the first time of use after opening Freeway. In this case I have to do the setting manually.
• I often set text by cutting and pasting from another source. I then highlight my total text in the panel, and set the correct format (in my case Arial/white/14 pt). If I set the Arial, and then proceed with the following settings, frequently the text reverts to Arial Hebrew – the setting below Arial – and I have to reset Arial. (This problem may not be specific to Arial/Arial Hebrew?)
Cheers,
Paul
Hopefully you are using a plain text source?!
Also have a look at Thomas’s latest screencast - follow this and you will never have to set your paragraph font again.
http://kimmich-dm.de/wordpress/?p=931
Thanks Dave. A helpful post! :slight_smile:
