Recently, I’ve noticed that when I’m typing text in an HTML box that nothing is happening. However, when I click out of the box everything I typed is there. Sometimes, after a few of these weird episodes Freeway Pro will crash altogether.
Is this an issue with Freeway Pro or Mac OS X 10.7.4?
Are you using the latest version of FW? - 5.6.4
Yes, 5.6.4 (6412).
waltd
(Walter Davis)
June 12, 2012, 4:28pm
4
Check to see if any of your fonts report an error. In Freeway, Edit / Fonts and click the [Errors…] button.
Yes, 5.6.4 (6412).
I asked because your FWT tag says 5.5.6
Fonts are a favourite culprit.
Oops! Forgot to update that. Thanks for noticing.
Indeed there are:
Font Problems
June 12, 2012 12:35:14 PM
INTERNAL FONTS. The following fonts are for internal use only.
Font: “.Aqua Kana” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:AquaKana.ttc”.
Font: “.Aqua Kana” Style: “Bold” File: “Mac OS X Lion:System:Library:Fonts:AquaKana.ttc”.
Font: “LastResort” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:LastResort.ttf”.
Font: “.Keyboard” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:Keyboard.ttf”.
Font: “.Helvetica Neue Desk UI” Style: “Bold Italic” File: “Mac OS X Lion:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Italic” File: “Mac OS X Lion:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Bold” File: “Mac OS X Lion:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Times LT MM” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:TimesLTMM”.
Font: “.Helvetica LT MM” Style: “Regular” File: “Mac OS X Lion:System:Library:Fonts:HelveLTMM”.
What does all of this mean and how do I go about fixing it?
waltd
(Walter Davis)
June 12, 2012, 4:49pm
8
I don’t think you have to worry about internal fonts. Are there any other errors reported?
On Jun 12, 2012, at 12:37 PM, RavenManiac wrote:
Indeed there are:
Font Problems
No, none that I can see.
BTW, why would that message even show up. As I recall, none of those fonts are being used in my FWP document.
This could be my crappy Logitech wireless keyboard. My old one broke, which I loved, so they sent me a replacement, but it’s not Mac compatible. According to my Logitech CSR, they are out of the Mac business again, except for a few solar-powered keyboards.
Nope, not the keyboard. I just swapped out the Logitech with a new Apple wired keyboard I have and I’m having the same problem. Any other ideas?
waltd
(Walter Davis)
June 12, 2012, 5:29pm
13
See if this works: type the text into the box, then scroll the Freeway design window until the text box is hidden off screen, then scroll back. If you then see the text, I think what you are seeing is a fairly common screen-painting bug. It’s worse in boxes that have overflowed content or that are set to no height.
Yep, that’s the problem. I never recall this happening until I changed over to inline layouts with no height boxes.
It’s really a pain though.
I have a similar problem with FWP not rendering type, except I can clear it
up by republishing (command-p).
Sometimes styles and such don’t render in Layout mode until I hit cmnd-p
again.
It’s the little things like this that make coding by hand more tolerable.
