at times on ftp upload to the server (always on 1st upload on a particular day) a window comes up saying
THEN i just upload again and it ALWAYS goes through and updates the site.
I suspect the problem arises from how I moved the site from a MacMini with Snow Leopard {with several _blank.gif files; while there are none by that name on the iMac using Yosemite
I hesitate to move a _blank.gif file for not sure which one or where to put it if I did. for the way I moved the file to the iMac shows no overall resource folder/file
I too have experienced this issue and as a rule the 2nd call to Upload finds the ‘missing’ _blank.gif which incidentally is a FW created object that you have no need to create.
I too have experienced this issue.
I have also experimented that elements used in the UploadStuff action are not overwritten but duplicated on the server.
My different files in Pro 7.01 have a _blank.gif in 6 different site folders.NONE FOR THE designated SITE.
THERE IS A _BLANK.GIF IN AN OLD Freeway Express folder where I had started a BlankNewWebsite and no longer used it.
ACCORDING to a searchI just did that -blank.gif was accessed yesterday at 10:;40 am … SO MAYBE FW pro finally found one. Be interesting to see what happens on next upload
