Thank You thats what I was asking for David. I already purchased it and now my question is once I download the update will it automatically implement it or are there additional steps involved?
If you still want the option of using an earlier version of FW (your current one) then select the old version in the finder and change its name to Freeway 5.X
The new version (once you have downloaded it and unzipped it) will come in a Folder as Freeway Pro.app and the Showcase.app
These can be dragged into your Applications folder to install them (if you renamed the old version then it wont be overwritten by the new)
Launching the app (by double clicking) is no different than before and then you are ready to get started.
