Having used Pro 4 for approximately two years, I downloaded a trial version of Pro 5 for a test drive on a computer other than the one on which my site work has been done previously. I copied the files from Pro 4 site folder on old computer to new computer with the Pro 5 trial and did some work on the site. When I try to preview the work, I got the following message:
Could not complete the ‘Publish Site’ command because file not found.
(-35:270:226)
Did I “forget” something by simply trying to drag and drop the site folder from one computer to the other?
Is your publish folder still set to a path on the previous Mac?
Just set it a one on the new Mac and you are ok.
regards
Brian
ediporter said recently:
(-35:270:226)
I must’ve ridden the short bus to school this morning: How do I set the path to the new Mac? I’ve tried telling it to Publish but get the same 'Could not complete the … " message.
