I know there heas been an action in the past, custom made, to give us the capability to upload more stuff than the standard 10 items to the Resources folder or the html-location of the page the action was applied to. Any idea what that action was, and does it work for FW 5.6.4?
Is it possible to create a folder-action that allows us to upload (far more than 10) resources to a specific folder? That would be the awesome, and most possible the best thing ever at this point.
Upload Extra Resources Upload Extra Resources - ActionsForge is an Item-Action, so you can apply one to each element on your page if you like. Whenever you click on that element, you see the interface to attach files in the Actions palette. So theoretically, you could have thousands of extra files hosted from a single page. You might find it more manageable to upload those files separately with Transmit or Fetch, though.
Ah, I see what you mean. Patchwork, but it does the job.
But it wasn’t the action I remember. I knew it made me able to select dozens of items. But the action you pointed out seems to do the trick in the mean while. Still hoping for a cleaner solution though. Freeway 6 perhaps … in a couple of years
