Hi all,
I currently work on a project that needs to be upload to a subfolder on my main root. It works like a charm, however I still wonder if these upload settings I use, have the correct terminology (slashes) or is Freeway probably correcting my free state of the art?
Thanks for filling the black holes …
What I do to achieve this is to create or duplicate to a new Freeway
file with all the same logon credentials as the base site.
Then create the new pages/content in a subfolder [news] or the name you
want to use in the site palate. then when you upload FW will create the
folder name [news] as in the site palate.
Then all you need to do is make links /news/index.php or
http://www.cpja.org.uk/news/index.php] from main site menus to the new
“mini-site” Such as:
Main site: cpja.org.uk
New Mini-site: cpja.org.uk/news
Peter
Thomas Kimmich mailto:email@hidden
22 July 2011 08:34
Hi all,
Skitch | Evernote
Best wishes Peter
Peter Tucker . Oxford, UK . email@hidden
Hi Peter,
yes - sure, but the sense of my effort is, that I like to ship your so called “mini-site” as a template freeway-page ready to use.
This template page finally will shoot a lot of necessary scripts on the clients account. For this it is very important to have the correct path settings (terminology) in my mini-template page, cause it will be finally including stuff into current projects (where you just need to build a same named folder eg. “subfolder”) but from an external, second source (mini-template).
I’m just unsure what the setting in mini-template would be:
/subfolder/ or subfolder/ or /subfolder or even subfolder
within the directories to make sure that it is a justwork.
I can’t actually tell more details on it cause I’m not sure if it will work as expected - and for this, each detail counts.
This link generates a 404 not found error…
André Rombauts
Belgium
What I did was to copy the FW file with all it’s templates and then
delete all the page content leaving the templates. Then make a folder in
the site palate and populate it with the pages I wanted there.
Then using relative links, in the original FW file in the menus/links I
put in “Other” /news/index.php so that it would link to the new content
and in the new content, I put in links “Other” …/index.php to go back
one directory level and find the index page in the main site.
22 July 2011 09:46
Hi Peter,
Peter Tucker mailto:email@hidden
22 July 2011 08:58
you want to use in the site palate. then when you upload FW will
create the folder name [news] as in the site palate.
Peter
Best wishes Peter
so /subfolder would be the correct pathsetting (as I have it already in the screenshot).
