Hello,
We currently have the action ‘Upload Stuff’. The action works great but there are some extra capabilities we need.
Ability to upload folders. I have a folder with about 60 images that needs to be uploaded. First there are not even enough upload spaces to upload all 60 pictures and even if there were it would be time consuming to do. So it would be so much easier to upload just the folder and all the image files inside would come with it.
More destinations to upload to. For example we have documents we want to upload to the css folder. Even better could the destination folder be selectable.
If anyone knows another action or way to do these things we would greatly appreciate the help.
Unfortunately the Action is limited by the available options in
Freeway so it wouldn’t be possible to do either of those. For more
control you would be better off logging onto your server using an FTP
application such as Cyberduck (free - http://cyberduck.ch).
Hope this helps,
On 19 Aug 2009, at 20:45, TeamSDA wrote:
Hello,
