I am still seeing the action created google code
<script src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAHrkYefNE9nZDeWicVstjRRQ9iCcWoUQOrnjn4K-BHyqQgt3WhhTkyr-2yHYAfOrqsaM6sO87kYFemw&hl=en&oe=ISO-8859-1" type="text/javascript"></script>
And while it works when visiting .co.uk it doesn’t at .com
What method did you use to delete this code from your page? If you did it directly on the server and have reuploaded then FW will have undone your work.
PKelly
(PKelly)
July 17, 2011, 3:43am
42
I did it directly on the server then reuploaded. So what would you recommend?
P
If you do it on the server and then update your site then the page will be overwritten by FW.
Instead use the Source Code Snooper action.
But at least you now know it works!
PKelly
(PKelly)
July 17, 2011, 12:15pm
44
Well, I’ve deleted that line using Source Code Snooper and still the .com/findus.html doesn’t work.
P
Strange - it worked for me!
PKelly
(PKelly)
July 17, 2011, 9:17pm
46
Hmmm…maybe I need to clear my cache, or something.
P
Try a different browser that you haven’t used to see that page.
