I’m using 5.5.7 Pro and have created a relatively simple site. When I upload minor changes Freeway always uploads the entire site. I tried changing the output settings to ‘common resource folder’ but that didn’t make any difference. Any ideas?
Some changes made to sites will need a complete republish. Try uploading immediately after doing an upload (without making any changes) to see if Freeway uploads everything again. Note that it can look as if it’s uploading but will just be analyzing files on the server to see if they need updating, this takes considerably less time than uploading.
If it is uploading everything again then get in touch with our support team who will try and pinpoint the problem. Note that they may ask to see your file. You an contact them here: Softpress KnowledgeBase :: Softpress KnowledgeBase
