[Pro] Urgent help please
I have asked this question before a few months back and received a reply which solved the issue but i cannot find it anywhere…
I have a site I am working on where the CSS drop down menus hide behind the target show hide photo show below.
Bring to front and bring forward does not work.
I solved this in version 6 from a reply a couple of months back but since I have just upgraded to version 7 and it has reverted back to being ‘behind’ the whole time.
I need to send a proof to a client in the next few hours please help!
Steve
Can you post a link to an example page showing the problem?
Thanks Waltd
Here is the one on v6 which works
http://www.hertscreative.co.uk/customer/1/index.html
And here is the same version on v7 where the drop downs disappear under the images
http://www.hertscreative.co.uk/customer/2/index.html
Hi,
in this case, select #header1 and via item->extended add position (name):relative(value) in the DIV-Style tab dialogue.
It currently states -
name : z-index and value: 99
So what do I need to change ?
Steve
leave z-index as it is and add as a new name/value pair position:relative as figured out above.
Excuse my ignorance but you have confused me ! Can you explain further please?
I have done as you said and there is no change,
Steve
Excuse mine - but you haven’t (at least I can’t see that you did).
So select the item header1
Choose item → extended, there the DIV-Style tab and add as new name/value pair position (name), relative (value).
UPLOAD this so I can see it.
ok thanks - I have uploaded it (it is the 2nd link above)
If you would do what I told you, it’ll work.
You did:
Overlay: 100 (who told you this - me?)
I said:
leave:
z-index (name) 99 (value) (as it was)
and add
position (name) relative (value) as a new pair!!!
If you can’t do those two simple things, let me know. I’ll take the next flight to you and do it by myself.
… something like
Now that’s what I call great customer service. :slight_smile:
LOL
Cheers Thomas… You Genius… It worked!!
Sorry… I am stressed and got confused…
You can still fly over and I will buy you a Pint of the best British Beer i can find :slight_smile:
Steve
There is a nice Chinese saying:
If you’re in a hurry - wander off
I’d love it - for sure.
