I have built my site with 5.4.3. When they came out, I tested 6 and then 7 and both times there were too many mistakes in the rendering of the site between versions that I just settled back into 5.4.3. But now I want to install a site search. Looked around and found that 5.5/5.6.5 have the built in folder action “simple site search”. So I downloaded the 30 day trial and put search on my site. My question is, when I go back to 5.4.3 after 30 days will the function simple site search still be there? Will uploading from 5.4.3 again, overwrite the progress I have made?
Wrong. There are too many mistakes within your page-construction causing this. The truth is in the browser, anyway.
The thing is, that you won’t be able to open your document anymore. So I’d call it a rather bad idea doing so. Freeway never was backwards compatible.
