I have a find button which should go to a new page. This page’s content does not publish. All the rest of the site publishes fine.
The file is on the server but is 0k
Tried renaming and republishing. No luck.
schoolphotopro.com
I had to link to another page. Whatever I do, the page schoolphotopro/find.html will not show.
The find button is linked to
directoryindex.html
and if this is expected, it works.
Had to move the link to get it sorted by the end of the day.
schoolphotopro/find.html is there but empty
Yep - in this file is for sure some corrupt or misplaced code causing this. The point is:
It is empty - so it’s (at least me) impossible to tell you what happened. Remove all actions/external code and try it again.
… or tell us what actions/external code did you use.
